Specifically a density, volumetric shrinkage, or time to eject plot. In 3d I like to set up a animate results over single data set, I pick the last time frame, use the default 24 frames to animate, and in the case of density I plot lowest to highest to show the internal structure of part and the lower densities at thicker cross sections. In shrinkage, I show the highest to lowest to get the same result, and time to freeze I plot highest to lowest to show the internal features of part an where the part takes the longest time to freeze.
The problem is that with 24 frames, I only get results on the 22,23,24th frame of any animation. I tried this on a couple different models, but still only get results on the last frame in a true 3d plot. So, if I use a cutting plane, all the results are there for all 24 frames, but still on the 22-24 frame I get the cutting plane and 3d plotting of result.
It always worked in the past as far as I know, so I modeled up a smaller test model, and it still does it. So I attached images of it.
What is the fix for this?
