Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
AFTER INSTALL DOES NOT APPEAR THE SOFTWARE
3 REPLIES 3
jorge.lopera
1019 Views, 3 Replies
I have installed Moldflow Insight Ultimate2015 x64 on a 64bits DELL Laptop.
 I have downloaded from subscription portal.
When I try to open the program, the only options that shows me Windows are:
- Autodesk simulation Moldflow Insight Forums
- Tools
    Autodesk Simulation Moldflow Insight Command Shell.
I have tried to uninstall clean with the recommendations, even deleting de keys at regedit, but nothing.
I was looking on the installation folder at "Program Files" if is there any manual .exe to run, but nothing.
Do I have to install another feature?
Technical Specialist
Nexsys de Colombia
3 REPLIES 3
zhangchar
in reply to: jorge.lopera
You also need to install Moldflow Synergy 2015 if you need UI. If you only installed Insight then you will only have these two short cuts you mentioned, but .exe should be under "Program Files\Autodesk\Simulation Moldflow Insight 2015\bin" folder.
Charlie
jorge.lopera
in reply to: zhangchar
thanks Charlie,
Do you know if I have to pay for another license to install the Synergy?
thanks
Nexsys de Colombia
zhangchar
Yeah, Synergy needs its own license which is different from Insight license.
Regards
Charlie
