I did my moldflow simulation with a 3D-Solid mesh (MFI 2014 Ultimate). Is it possible to export the fiber orientation tensor in *.ele format. Actually I can only export in *.nod format.
I need the *.ele format for import in CONVERSE.
Thank you for your help.
rh
Solved by nordhb. Go to Solution.
yes, it is possible.
To be able to export 3D fiber result as *.ele create a new plot such as:
New Plot > Fiber orientation tensor on elements
Then you can export this as Patran and *.ele file.
Hope this solves your issue.
Berndt
Dear Berndt,
I did not find this export (.ele) format in "Autodesk Simulation Moldflow Insight Premium 2014".
Is it limitted to "Ultimate" licesne ??
regads,
Prasanna.
Hello Prasanna,
for fiber orientation simulation and results you need:
or
Autodesk Simulation Moldflow Insight Ultimate
See feature comparison at:
http://www.autodesk.com/products/simulation-moldflow/compare
Berndt
