Dear all,
I used to convert my Fusion mesh (done in Hypermesh) in to 3D in moldflow. After converting into 3D mesh, should I needed to use Mesh => Mesh Repair Wizard for automatic correction?
Thanks in Advance.
It's not absolutely necessary, but it's better.
If the Maximum Aspect Ratio of the Dual mesh is low (around 12), you'll see that the Wizard won't change the 3D meshing.
Signature: "Maybe Moldflow does not work properly, but the real world neither" my son...6 years old 😉
