I have made a cool analysis for a 3D tetra mesh component, the analysis is running fine without errors but none of the cool results are not available. This gets solved if the flow rate is changed and also if it is run with fusion/DD meshed part. The part has been meshed in CATIA and imported in AMI 2012 with nastran format. I have tried with remeshing in moldflow as well.
Software: AMI 2012 with SP2
Coolant: water
coolant flow rate: 5L/min
coolant inlet temp: 60°C
cooling line dimensions: Channel 10mm dia and baffle 19mm dia
please have a look at the attached pictures one with flow rate 5L/min and another picture with 6L/min
recommend you to upgrade to the latest release, Autodesk Simulation Moldflow Insight 2014.
Berndt
