I am trying to simulate resin flow in Moldflow. For that I need to determine the Rheological behaviour of the resin.
Can someone tell me where I can find the formula that links the 13 coefficients to the plotted graph of density vs temperature at constant pressures? I can't find anything usefull when I search for the 2-domain pvT Tait model.
Thanks in advance.
Greetings, Anton
if you have measured data, raw data or data points, of material you can contact
Autodesk Moldflow Plastics Labs ( http://usa.autodesk.com/adsk/servlet/item?id=13151393&siteID=123112&linkID=13030537 )
at datafittingmoldflow@autodesk.com and get measured data fitted and an udb-file for analysis in return.
Berndt
