Dear all,
What are the different mesh terminology used in moldflow.
1D - Beam elements (boss, feed and cooling system)
2D - Triangular elements on midsurface (Midplane mesh)
2.5D - Triangular elements on Surface (Dual domain or fusion mesh)
3D - Tetras (3D mesh or volume mesh)
Is it OK to refer the dual domain mesh as 2.5D mesh?
Please share your views.
Regards
JK
Hi
I guess, the mesh terminology in moldflow are
2.5D - Triangular elements with thickness assigned (Midplane and Dual domain also called surface mesh)
3D - Tetras (3D mesh also called volume mesh)
Please share your views if my understanding is correct.
Regards
Ramesh
Ramesh's response is correct. There is no 2D analysis.
