Show only
Search instead for
'@ DESCRIPTION '@ Take the Standard Thickness Diagnostics Plot and convert it into a custom plot '@ '@ SYNTAX '@ CustomThickness '@ '@ PARAMETERS '@ none '@ '@ DEPENDENCIES/LIMITATIONS '@ Assumes a study file is open within synergy '@ none '@ '@ History '@ Created DRA 9/9/2006 '@@ Option Explicit 'SetLocale("en-us") Dim Synergy Set Synergy = CreateObject("synergy.Synergy") 'Synergy.SetUnits "Metric"
Dim DiagnosisManager, PlotManager, Viewer Dim Elems, TH, ARPlot, Plot
' Get Thickness diagnostics Set Elems = Synergy.CreateIntegerArray() Set TH = Synergy.CreateDoubleArray() Set DiagnosisManager = Synergy.DiagnosisManager() DiagnosisManager.GetThicknessDiagnosis 0.0, 10, Elems, TH Set DiagnosisManager = Nothing ' Create user plot Set PlotManager = Synergy.PlotManager() Set ARPlot = PlotManager.CreateUserPlot() ARPlot.SetDataType "ELDT" ARPlot.SetName "Thickness" ARPlot.SetDeptUnitName("mm") ARPlot.AddScalarData 0.0, Elems, TH ARPlot.Build Set Viewer = Synergy.Viewer() Set Plot = Viewer.GetActivePlot Plot.SetNodalAveraging False Plot.Regenerate
I think it can be a default result in fill analysis, because is very useful.
