Size - Remelt zone
Size - Remelt zone
Hello together,
for an analysis I have to evaluate the remelt zones in a Mold Flow simulation between the injected plastic and an thermoplast-based insert. Unfortunately the remelt zones in the model are only displayed visually.
For an quantitative compairision between different simulations it would be nice to get an value which reperesents the surface or the size of the remelt zone.
Is it somehow possible to get this information out of Mold Flow?
Many thanks in advance for all support. Smiley Happy
Best regards,
hennsym
1 Comment
Hello Hennsym,
you can achieve something similar to what you are requesting if instead of using the re-melt zone result you use the temperature result as a single contour set to your desired temperature. More than 6 layers of elements is advised.
Best regards,
Eduardo
