Summary
A proposal to simplify modeling Baffle features in a cooling system.
Problem
Currently, every baffle requires two separate lines to create a baffle. Users can either make a small V configuration or the two lines can be coincident. However, if at any time the nodes get merged on the baffle line then the solver interprets the baffle as a dead-end. This issue is especially problematic if using HyperMesh to generate a Moldflow mesh file.
Solution Proposed
Eliminate the second line needed to generate the baffle. The necessary pressure drop should be automatically calculated by the solver. The solver should also be able to tell which direction the water is moving based on the coolant inlet boundary condition. This is similar to other softwares on the market.
