Normally we are facing trouble to select correct mesh type for the product . whether use DD or 3D .Instead of this ,if it is possible You can change the option like always use 3D meshing.
then try to improve the mesh accuracy , result accuracy and reduce the meshing time and analyse time if it is possible.
Prabu.K
