Merging two nodes
Merging two nodes
Some times we may need to merge two nodes and the resultant node should form at the center of merged nodes.
is it possible to have a check box and if it is checked the resultant node will be at the center of merged nodes
M P Pradeep Kumar
6 Comments
raalteh
I'll admis this is not exactly the same as the request of merging to a node in between, but in the insert nodes, there is an option to create a node in between two selected nodes (and it will fix up the mesh nicely).
The problem with the request in its current form is that it would require a special flavor of the merge nodes, specifically for two node merge (where we currently can merge many to one node). It would be unclear what to do in the 'many to one' node merge.
raalteh
Status changed to: Comments Requested
mppkumar
we can insert a node between two nodes and merge the two nodes to the newly inserted node
but this takes more time if we intend to merge more nodes;
instead if we have a option of merging two nodes (only) and the resultant node will be the midpoint of the two nodes, this will save time
For "many to one node" merge, this option wont work. To avoid this scenario, we can have a check box, if it is selected need input of two nodes only
VittorioMarzona8253
I agree with the idea (I use this option as default inside Hypermesh in preparing mesh for MPI). To simplify the life, maybe the "Merge in between" could be only available with "Automatic apply" flagged.
mppkumar
@vittorioMarzona8253
If you are agreeing with this option, please provide "kudos"... AutoDesk will implement the options with most kudos
raalteh
