Show only
Search instead for
I'll admis this is not exactly the same as the request of merging to a node in between, but in the insert nodes, there is an option to create a node in between two selected nodes (and it will fix up the mesh nicely).
The problem with the request in its current form is that it would require a special flavor of the merge nodes, specifically for two node merge (where we currently can merge many to one node). It would be unclear what to do in the 'many to one' node merge.
I agree with the idea (I use this option as default inside Hypermesh in preparing mesh for MPI). To simplify the life, maybe the "Merge in between" could be only available with "Automatic apply" flagged.
