Show only
Search instead for
Allow plot windows to be managed (repeated location) or at least keep the same location with the same loaded studies. With ‘clean screen’ and ‘tile’, changing plot types will usually rearange plot locations making pasting into comparison reports very difficult. Requires manually moving and resizing windows. This case has 4 different studies loaded for comparision. The report needs to hold locations as the plot type are loaded.
or at least be able to open 4 studies and have the 1st selected be in the top left corner, the 2nd selected be in the top right corner, the 3rd selected be in the bottom left corner, etc.
With all the studies open that you want to tile, click in each window in the order you want them aranged. The when you hit tile, it will arange them in the order clicked.
