It would be a big help for my analysis if I could export STL files of actual warped geometries, but with the deformation of selected axis only.
Example: If I need to glue or weld complicated geometries, I don't have to care for Flatness only, but also for the generell fit of all geometry.
The analysis takes place back in Cad, or GOM Inspect.
And there the flatness is a problem sometimes, if only I could "switch that off"...
The idea is originated here:
http://forums.autodesk.com/t5/simulation-moldflow-insight/export-warped-geometry-but-restricted-to-x...
Regards
Harald
