Summary
Can we set coordinates as anchor nodes rather than the node number
Problem:
I found that in post-processing warpage, we can only select mesh nodes for anchor nodes/plane.
May we set coordinates as reference anchor nodes/plane?
As in reality, we can know the cooridinates of the reference anchor, but need extra work to know the node number (and some time mesh node doesn't existed there).
Solution Proposed:
Can we find the nearest mesh node of the coordinates, or even better to use the coordianates directly.
Do you guys have similar request/scenario during your daily work?
Thanks!
