One of my prospects is asking whether he could run AMA on his laptop, under Windows 7 Home Basic. Now, in the Release Notes it's stated that the minimum requirement is W7 Professional...
My question (out of curiosity): which AMA/AMI functionalities are NOT functioning under W7 Home Premium, and which Professional OS features are required?
Cheers
Piotr
Hi Piotr-
as this is a user forum, You may have more luck if you contact your autodesk support or supplier directly?
Personally I run win7 pro 64bit, and will not waste my time trying to save a few hundred dollars on a decent OS, as the time savings alone will soon cover the cost of the better OS.
