Discussion Groups
Simulation Moldflow Adviser
New Member
tomas.fiala
Accepted Solution
Warpage Results
522 Views, 2 Replies
02-05-2013 06:58 AM
Hello friends, can you give me an advice, how to set the warpage analysis to get results of different effects?
I have created mold, cooling circuits and runners and set all analysis to be performed, but the result of warpage is only "all effect" and I am not able to got "orientation effect", "differential cooling"... even I have tried both "cooling quality" and "cooling" analysis. what I am doing wrong? Thank you for any tip.
Please use plain text.
Product Support
nordhb
Re: Warpage Results
02-06-2013 02:55 AM in reply to: tomas.fiala
the reason for this, is that you are running a 3D analysis.
In Process Settings, tab Advanced:
Check: Disable aggregation for 3D warp analysis
This option is by default unchecked.
Aggregation reduces analysis time and memory usage in most cases.
By disable the aggregation for 3D warp analysis, it provides a more detailed set of Warp analysis results.
The Warp analysis will take longer.
Hope this helps.
Kind Regards,
Berndt
Berndt Nordh
New Member
tomas.fiala
Re: Warpage Results
02-06-2013 03:33 AM in reply to: nordhb
Hello, thank you a lot. Now it works. Tomas _____________________________________________________________________________________ Tomas Fiala | Schneider Electric | Global Supply Chain | Czech Republic | EMEAS - Moulding Specialist Phone: +420382766450 | Mobile: +420734646112 Email: tomas.fiala@schneider-electric.com | Site: www.schneider-electric.com | Address: Schneider Electric CZ s.r.o., Sedlackova 7, 397 12 Pisek, Czech Republic *** Please consider the environment before printing this e-mail
