Hello friends, can you give me an advice, how to set the warpage analysis to get results of different effects?
I have created mold, cooling circuits and runners and set all analysis to be performed, but the result of warpage is only "all effect" and I am not able to got "orientation effect", "differential cooling"... even I have tried both "cooling quality" and "cooling" analysis. what I am doing wrong? Thank you for any tip.
Solved by nordhb. Go to Solution.
the reason for this, is that you are running a 3D analysis.
In Process Settings, tab Advanced:
Check: Disable aggregation for 3D warp analysis
This option is by default unchecked.
Aggregation reduces analysis time and memory usage in most cases.
By disable the aggregation for 3D warp analysis, it provides a more detailed set of Warp analysis results.
The Warp analysis will take longer.
Hope this helps.
Kind Regards,
Berndt
