Hi
For warp analysis, % of warp quality depicted in results log is different from what it shows in screen. Pls find attached image for reference.
Which values should we consider?
Hi Dinesh,
had a look on the picture, and what you see is correct I would say.
This is how it is derivated:
Log "Percentage exceeding Nominal max. deflection" = warpage indicator, the red part of label = 0% in your case
Log "Percent within Nominal max. deflection" = green + yellow part of label = 93.8% + 6.16% = 99.96%, seen as 100% in Log, so a round off and a very small discrepancy.
If you change reference from best fit to using reference points and/or changing the nominal max deflection for warp constraints, the warp indicator result will update, and the information in log as well.
From what I can see this work as expected.
Hope this explains.
Berndt
Hi Nordh,
As per warp result indication:
Green - within 80% of nominal max. deflection of part
Yellow - 80-120% of nominal max. deflection
Red- more than 120% of nominal max. deflection.
The attached picture has regions which are yellow in colour , which can be even 110% of nominal max. deflection. So how can we assume its within nominal max. deflection.
So instead of depicting results this way in log sheet, it wil be useful if they can show it separately for 80-100% and 101-120%.
Hi Dinesh,
I could not see a picture attached to your post.
From the Nominal Max Deflection value (NMD), which you can set as well, you can calculate as for example:
NMD = 0.40mm
Green = from 0 to 80% of NMD = 0 to 0.32 mm
Yellow = from 80 to 120% of NMD = 0.32 to 0.48
Red = from 120 % of NMD and above = 0.48 and higher
You can change the NMD value, to better suit your analysis of warp indicator result.
If you want all of 0.40mm to be green, you need to set 0.5 as NMD, then 80% of 0.5 is 0.4mm.
Above 0.5 mm will be yellow.
Where to change:
Berndt
Hi Nordh,
Hello Dinesh,
thank you for clarifying this, and I do get the point.
This links to Simulation Moldflow Idea Station
Here enhancement requests and ideas are posted, and users can vote by kudos.
The Simulation Moldflow IdeaStation is reviewed by Simulation Moldflow Development Team.
Review guidelines and best practices before posting a new idea.
For the NMD information in Log, I will discuss internally to see if this could be improved in some way to be more clear and concise.
Thank you.
Berndt
