Hi
from one of our analysis, we have found that results varying for varying coordinates keeping same injection location. How does it varies? reason for the same? I have attached same analysis file.
Wating for reply
I had a look of the provided studies, and they differ a little in mesh element numbers (there are about 69.000, and difference is 100) and slightly in node distribution on side of gate.
I am not sure of the model manipulation here, but the copied part has somewhat fewer elements.
The small difference in result is due to small difference in mesh, and running Automatic for fill settings when comparing.
I noticed that fill time and switch over was set to Automatic.
When comparing I would recommend to use the same values, and set a fill time and switch over.
Doing this, there is a very small difference of result and well within acceptance, I would say.
Hope this helps.
Berndt
Hi Berndt,
I agree with you that deviation are very small, but my concern was with symmetricity of the part. I meant to say you can find in one study injection pressure along the four edges are uniform, but in other case you can one edge alone varies from other edges.
Also that is just an rectangular plate which was analysed to share with you, actually in one of our part we found these variations after changing there coordiantes along the XY plane:
Fill time: There was much change in the filling pattern, initially we found back fill phenomenon but after changing the coordinates wefound it was not observed.
Injection Pressure: Deviation of 795Psi was found.
Temperature at flow front: This results were greatly influenced , before changing the coordinates we found one side of the part had lesser melt temperature compared to other. but after changing the coordinates we found there results were almost nowhere simliar to prior one.
Warpage: We found there was difference of 5% deviation in warpage quality of the part.
So it will be helpful for us to get better results if you can say a solution for this issue.
Hi Dinesh,
thank you for the information.
For your request about the specific part, please raise this as a technical support request
at the subscription center: http://subscription.autodesk.com/
An investigation of your part in more details can be done and to understand the issue.
Kind Regards,
Berndt
