Moldflow Adviser Forum
Welcome to Autodesk’s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
units for mfr file
2 REPLIES 2
mlentz
724 Views, 2 Replies
units for mfr file
When creating a MFR file, how do you control what the output units will be?
Would like to have dual units (english/metric)
2 REPLIES 2
Shawn_Gedman
in reply to: mlentz
There is no need to assign units when exporting an mfr file for Communicator since they'll be maintained automatically after the model is imported into Adviser.  We can change the units that you're viewing the model and plots in after importing the model though.
To change the display units in the Ribbon, open the Application menu, select Options, and you may change the display units in Communicator between English and Metric right on the General tab.  For the Classic interface, go to File, select Options, and change the units on the General tab.  Unfortunately Communicator does not have the option to view the model in dual units like Adviser does.
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
nsanwal
in reply to: mlentz
hi,
The defult units are published in creation of .mfr.You can change the default unit system as per your requirement.
nsanwal
