Moldflow Adviser Forum
Welcome to Autodesk’s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
TUTORIALS - FORBIDDEN ERROR
1 REPLY 1
ashish_gollapalli
324 Views, 1 Reply
I'm getting a FORBIDDEN ERROR on the webpagne when I try to access the tutorials from the Advisor software. It worked earlier but recently it stopped.
Need some help here. Thanks
1 REPLY 1
nordhb
in reply to: ashish_gollapalli
this might be related to you internet connection.
By default Moldflow Adviser 2014 will try to use on-line wikihelp.
The on-line tutorial is accessible here: Tutorials Adviser 2014
You can switch to local help:
Switching to Local Help in Simulation Moldflow 2014 Products
But if you have internet connection issues, you can use local help:
1) Access the Options via the application menu.
2) Navigate to the Language and Help tab in the options.
3) Modify the Help to launch locally: check "Use local help"
4) Apply
Hope this helps.
Berndt
Berndt Nordh
