I have been deploying MFC 2010 and 2011 in the past without problems, but MoldFlow Communicator 2012 SP1 fails.
I am using the following command line:
amcpc.exe /SP- /VERYSILENT /SUPPRESSMSGBOXES /LOG /NORESTART
The log file contains the following:
2012-04-03 15:11:52.887 Log opened. (Time zone: UTC+02:00) 2012-04-03 15:11:52.887 Setup version: Inno Setup version 5.2.3 2012-04-03 15:11:52.887 Original Setup EXE: \\Haidlfs02\Software$\Moldflow\2012\Autodesk_Moldflow_2012_Multilingual_Win_32-64bit_Linux_64bit\amc2012\windows\amcpc.exe 2012-04-03 15:11:52.887 Setup command line: /SL5="$F0086,127077574,424448,\\Haidlfs02\Software$\Moldflow\2012\Autodesk_Moldflow_2012_Multilingual_Win_32-64bit_Linux_64bit\amc2012\windows\amcpc.exe" /SP- /VERYSILENT /SUPPRESSMSGBOXES /LOG /NORESTART 2012-04-03 15:11:52.887 Windows version: 5.01.2600 SP3 (NT platform: Yes) 2012-04-03 15:11:52.887 64-bit Windows: No 2012-04-03 15:11:52.887 Processor architecture: x86 2012-04-03 15:11:52.887 User privileges: Administrative 2012-04-03 15:11:52.897 64-bit install mode: No 2012-04-03 15:11:52.897 Created temporary directory: C:\DOKUME~1\ADMINI~1\LOKALE~1\Temp\is-S73FS.tmp 2012-04-03 15:11:53.659 Failed to proceed to next wizard page; aborting. 2012-04-03 15:11:53.659 Got EAbort exception. 2012-04-03 15:11:53.659 Deinitializing Setup. 2012-04-03 15:11:53.659 Log closed.
I think this is due to checking for 3Dconnexion.
A manual installation just works fine, but I won't run arond in the company and install ~50 systems manually.
Thanks in advance for any pointers,
Stefan
Solved by Derek_Hain. Go to Solution.
Hello Stefan
I spoke with one of the developers and got the follwing information. Hopefully this will work, if not their is a new release of 2013 communicator that shoudl be avalable for download soon.
comment:
Since 2012, we had have added Eula agreement, which is mandatory. So if the install command line is same as cited previously, but having for example
/eulalang=”enu” SP- /VERYSILENT /SUPPRESSMSGBOXES /LOG /NORESTART
will make the jobJ
regards
Hello Derek,
Adding the switch /eulalang="enu" solved the problem, thanks for the hint.
Where can I find information about the commandline switches for the installer, which are not standard Inno Setup switches?
Thanks for the fast solution.
