Moldflow Adviser Forum
Welcome to Autodesk’s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
Silent Install
6 REPLIES 6
pankram
1173 Views, 6 Replies
Silent Install
Any ideas how to silently install the client and have it point to a network floating license? I tried adding a registry key and adding an environmental variable, and it doesn't seem to be enough.
Max
6 REPLIES 6
raalteh
in reply to: pankram
Hi Max,
Page 15 of your installation guide should contain information on the silent installation of Autodesk Moldflow Adviser products.
I hope this helps.
Hanno van Raalte
Hanno van Raalte,
Product Manager - Injection Molding & Moldflow products
pankram
Thanks for the reply! I had used that information to get the MPA tool installed, however I cannot get the licensing tool to point to my license server without having to use the license tool manually.
Max
nordhb
in the command line did you use:
/mfpsserver="server_hostname"
where server_hostname is the hostname of your license server.
Can you add the command line here?
Berndt
Berndt Nordh
pankram
Hi Berndt,
Thanks for the reply! I tried that as well as adding the key to the registry. Neither seemed to work. The only way I can point to the correct license server seems to be by manually launching the "network license server settings" and typing it in.
Max
nordhb
Hi Max,
I have used following commands, which works fine and set the license server name when
looking via Start > Programs > Autodesk > License Manager (Moldflow) > Network License Server Settings .
You need admin privileges for the installation.
Autodesk Moldflow Adviser 2010 R2
C:\Documents and Settings\user>ama_full_eng_main_09251_004_wnx.exe /silent /mfpsserver="license_server"
Autodesk Moldflow Adviser 2010 R2 SP1
C:\Documents and Settings\user>a01_09333_x64.exe /silent /mfpsserver="license_server"
Berndt
Berndt Nordh
pankram
Thanks Berndt! That is exactly what I was missing.
Max
