Simulation Moldflow Adviser
1 Kudo
Accepted Solution
Resin Issue
431 Views, 1 Replies
04-11-2013 11:37 AM
Hello Autodesk Team,
i want to add my resin info my resin is an Acrylite FT15 and the manufacturer is Cyro Industries, i sent an email to moldflow datafitting and they answered with an udb file that already exists in the material database.
My issue is that the recommended processing info is different from the material supplier, and when i perform fill analysis moldflow says that the part quality is compromised.
i want to know if there is another way to get the precise material info in Moldflow.
The PDF file of the resin manufacturer is attached.
Thank you in advance.
Regards
Employee
9 Kudos
Re: Resin Issue
04-11-2013 08:15 PM in reply to: gochoats01
If you are unhappy with the recommended processing conditions you can easily create your own custom material udb file with your own data.
Go to Tools ribbon, press "New" button (second left in the Databases section). Select "Themoplastic material" and press OK
NewModel.JPGpress "New"
Press Databases button (in the right bottom cormer) Find your base material (e.g. search for Tradename having Acylit in it. Press copy button to copy the material into your specific database
Now you can edit select your new material and edit it: (click on it and press edit button) Change the description (to easier distinguish materials. and "Recommended Processing conditions.
Press OK to finish editiong material and then OK to finish worsk with the new databse
Now you can select and use your own modified material instead of the public material datafile
