Moldflow Adviser Forum
Welcome to Autodesk’s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
Require material data for Sumipex LG2
1 REPLY 1
fuzzy_jal
527 Views, 1 Reply
Does anyone know where I can get hold of the data (*.udb) file for sumipex LG2? By the way, sumipex LG2 is a high-flow grade PMMA, manufactured by Sumitomo Chemical.
Thanks.
1 REPLY 1
SimonRichardson
in reply to: fuzzy_jal
In the past, when we need a specific grade, we have contacted the manufacturer direct and they have been able to supply the UDB. this was with GE, I dont know if you will have the same result from this manufacturer. Alternatively I would run a search for a PMMA with a similar MFI through the material database found under Tools-> Search databases (in AMA2010) and also try match up the melt temps, and physical properties etc
