Dear All,
Although basic but I want to improve my knowledge about PVT Diagram of material. Can you please help me out for
1.How I can relate material PVT diagram with any of results or processing parameters?
2. In PVT diagram generally graph is given for 3 to 4 pressure values ,how I can predict which is better for my analysis.
Although very basic but I will be thankful if you are able to clear my doubt.
I am not sure that I fully understand your question but I will try to answer.
Rho_solid=1/V(p=0,T=T_room)
Rho_melt= 1/V(p=0,T=Tmelt)
Ususlly, a little bit of discrepience in densities provided and calculated does not affect the result much.
Another, often overlloked thing is the correspondence between b5 and T_phase_transfer in semi-crystalline polymers. Both are related to the onset of crystallization. Usually b5 is 5..10 degrees below T_phase_transfer (the software automatically tries to correct unusual relations between those temperatures).
