Is there any way you can fine tune the step amount when running a Plastic Flow animation?
Moldflow Advisor 2010
Solved by nordhb. Go to Solution.
if you by fine tune steps means change number of frames, you can change number of animation frames.
After selected the result Plastic flow
Right-click and select Properties...
tab Animation
Change number of frames.
or set the Value range in time
This specifies the number of frames to be generated for the animation.
Hope this solves your issue.
Berndt
