I am not sure of which result you refer to.
Changing the filler content for a material data set will no affect the viscosity coefficients.
The viscosity of a material is measured with a certain amount filler, hence kept.
Changing the filler content does not change the viscosity coefficients, hence flow result will look the same.
Hope this clarifies.
Berndt
Hi nordhb, Thanks for your reply.
I am talking about the results of "Fill time", "Confidence of fill"and "volumetric shrinkage".
Which output parameters shoud really be affeted with the filler adition?
I mean what is the use of the filler addition if it has no effect on the general results?
the material properties are normally tested in a lab.
Filler data information is used to direct simulation to use fiber solver, for fiber orientation and mechanical properites prediction, which affects warp results.
If you want to manipulate results connected to filling, then it is viscosity coefficients, thermal properties, PVT data.
The material properties is normally tested in a lab, and raw data measured is fitted to data file for simulation.
There is some information in this article that might be useful to you:
Material data is missing in Moldflow material database
Berndt
