Hi
I have just installed student moldflow adviser 2014 and wanted to go through the first tutorial "quick start filling analysis". I have an issue when importing the tutorial file.
Import Wizard - Model selection
Import -> Panel.ipt (2014 version)
Moldflow Adviser error
"Autodesk simulation moldflow design link import failed. Either autodesk simulation moldflow design link is not found, or the file type is not supported"
Any ideas? maybe student license is the problem.
Thanks for any help
Andrew
Hi Andrew,
In general there should not be a difference in student license. We may need to gather more information in order to investigate the issue.
Is there a way that I could contact you ?
Kah Chong
Moldflow Meshing Team
Hi, please keep the contact on this post as it may help others. This is your first post also:)
Andrew
Trust no one team
Hi Andrew,
Could you check if you have Simulation Moldflow Design Link 2015 installed and the subfolder of Simulation Moldflow Design Link 2015\bin\Inventor Server is not empty ?
Kah
Hi Kah
I cannot find the Simulation Moldflow Design Link 2015/2014. I am actually using moldflow adviser 2014 not 2015. I have attached an image of all autodesk products installed on my pc, hope this helps.
Hi Andrew,
Autodesk Simulation Moldflow Design Link 2014 is installed at C:\Program Files (x86)\Autodesk. Could you verify that ?
Thank you.
Kah
Hi Andrew,
Could you do the following ?
1. Check values for "original", "current" and "installlocation" in HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Autodesk\moldflow design link\2014.
2. Goto Options dialog in Autodesk Simulation Moldflow Adviser 2014. Select "External application" tab. Confirm that the location and version of Autodesk Simulation Moldflow Design Link match to the location and version where your AMDL 2014 is installed.
Kah
Hi Kah, I appriciate your ongoing support thank you.
I have posted the results of what you have asked. As I see it they do not match but will not change anything until you advise.
Hi Andrew,
Location in Options tab should be : c:\program files (x86)\Autodesk\Simulation Moldflow Design Link 2014\ .
Could you try if able to import the ipt file after you made the change ?
Kah
Hi Kah, I have changed the path as advised. It made no difference and same error comes up.
I think I may give up on this.
Thanks for your help
