Discussion Groups
Simulation Moldflow Adviser
New Member
0 Kudos
Moldflow Adviser 2010, how to setup the add-in option in Solidworks 2011
769 Views, 1 Replies
04-12-2011 09:40 AM
How do I add Moldflow to the "add-ins" in Solidworks 2011? I went to tools, add-ins..., and there is no selection to start the Moldflow add-in. I have Win7x64 with Moldflow Adviser 2010x64 loaded.
Thanks.
K.B.
New Member
0 Kudos
Re: Moldflow Adviser 2010, how to setup the add-in option in Solidworks 2011
04-21-2011 08:39 AM in reply to: KurtBaker8050
Found out when 2010 Advisor SP1 is installed it loads the Add-in option in Solidworks 2011.
If you updated to 2010 Advisor R2 SP1 it will not install the add-in and will remove the Add-in from the prior version.
So you must use the STL import option, just a few more steps.
