Discussion Groups
Simulation Moldflow Adviser
Member
2 Kudos
mesh size control
539 Views, 4 Replies
01-07-2013 10:58 PM
Autodesk must add the option to control the mesh size also for moldflow adiver package.
All competitors have this option in the basic mudoles & i don't understand why it is not avialble in the moldflow adviser.
Product Support
41 Kudos
Re: mesh size control
01-09-2013 04:41 AM in reply to: oren
you have an option in process settings, tab Accuracy, to check High Analysis Resolution.
This is a kind of mesh control, which creates a finer mesh with about 2-3x more elements.
(tab Accuracy is to the very right of the tabs, and might be hidden at first sight, use the ">" to the right of tabs to step to the next tabs)
Enabling this option produces a more detailed model that takes more time and resources to analyze.
Use this option to ensure a high analysis resolution for models with a high proportion of small features such as fillets and radii, or if you want to examine highly detailed results.
Hope this helps.
Berndt
Berndt Nordh
Member
2 Kudos
01-09-2013 05:17 AM in reply to: oren
I know about this option, I already tried it & It is not good enough.
Our company manufactures very small parts which requires very high accuracy.
Member
2 Kudos
01-16-2013 02:03 AM in reply to: oren
Is there any chance that in the next version it will be avialable?
Product Support
41 Kudos
01-16-2013 10:43 PM in reply to: oren
to work with meshes in a more controlled and detailed way, you need the next package level of software:
Autodesk Simulation Moldflow Insight.
( see features at: http://usa.autodesk.com/adsk/servlet/pc/compare/index?siteID=123112&id=14920771 )
To control meshes in a more detailed level is not within the scope of Autodesk Simulation Moldflow Adviser.
http://usa.autodesk.com/moldflow/
You can add ideas/suggestions at:
Simulation Moldflow IdeaStation
http://forums.autodesk.com/t5/Simulation-Moldflow-IdeaStation/idb-p/91
Berndt
Berndt Nordh
