Moldflow Adviser Forum
Welcome to Autodesk’s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
Mathematical formula
3 REPLIES 3
syful.mithun
531 Views, 3 Replies
HI, I'm doing my master's project using Moldflow Adviser. I would like to know the mathematical formula used by Moldflow, for both Adviser and Insight version. Can someone please tell me where can I find those information?
3 REPLIES 3
nordhb
in reply to: syful.mithun
these sources provide comprehensive information about refereed journals, books, articles, and theses related to plastic injection molding technologies.
Autodesk Simulation Moldflow Adviser:
ASMA Help >  User's Guide > Reference materials
or
http://help.autodesk.com/view/MFAA/2014/ENU/?url=/cloudhelp/2014/ENU/MoldflowInsight/files/GUID-86AC...
Autodesk Simulation Moldflow Insight:
ASMI Help >  User's Guide > Reference materials
or
http://help.autodesk.com/view/MFIA/2014/ENU/?url=/cloudhelp/2014/ENU/MoldflowInsight/files/GUID-86AC...
Hope this helps.
Berndt
Berndt Nordh
syful.mithun
in reply to: nordhb
Thanks for your information.
I would like to know how Moldflow treats the mold block. From Moldflow insight model I can see tempreture deviation in the block, also around the cavity of the part. But, there are no results showing about the mold block in Moldflow Adviser. Does both version use different boundary condition for heat transfer around the cavity? Thanks.
nordhb
Autodesk Simulation Moldflow Adviser uses co-ordinates of mold extremity for heat transfer calculation in Cool.
Autodesk Simulation Moldflow Insight can use Co-ordinates of mold extremity for heat transfer calculation in Cool,
hence no mold boundary meshing, wich is needed for temperature display on mold boundary.
In Insight you can create mold boundary mesh for temperature display on mold boundary.
This is not available in Adviser, by desgin.
Hope this clarifies.
Berndt
Berndt Nordh
