Moldflow Adviser Forum
Welcome to Autodesk’s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
iNTERFACING MOLDFLOW ADVISER 2014 WITH ANSYS
2 REPLIES 2
dinesh27mec
745 Views, 2 Replies
I need to interface my MFA 2014 results with ANSYS for structural analysis. Whether its possible ??
Thanks in advance
Dinesh Kumar D
2 REPLIES 2
nordhb
in reply to: dinesh27mec
there is a product called Autodesk Moldflow Structural Alliance 2014, AMSA.
AMSA maps mechanical properties calculated by Moldflow to Ansys.
You need Autodesk Simulation Moldflow Adviser Ultimate 2014
(see: http://www.autodesk.com/products/autodesk-simulation-family/compare/moldflow-products )
Compatible software.
ANSYS Classic 12.1 and 14, 32- and 64-bit versions
ANSYS Workbench 12.1 and 14, 32- and 64-bit versions
You can find Autodesk Moldflow Structural Alliance for download at the subscription center.
http://subscription.autodesk.com/
You need a valid account to access.
Note: All ANSYS analysis calculations that use Autodesk Moldflow Structural Alliance 2014 are based on a linear elastic material.
You have more details in the Autodesk Moldflow Structural Alliance, AMSA, installation guide which is available to download with the software.
Hope this helps.
Berndt
Berndt Nordh
nordhb
in reply to: nordhb
please, also have a look at this:
http://forums.autodesk.com/t5/Simulation-Moldflow-Adviser/Autodesk-Moldflow-Structural-Alliance-2014...
Berndt
Berndt Nordh
