thank you Martin, but the problem is about the curves' lenght. The leght in moldflow is 25,4 times more than real (2,54 factor mm-inches x 10 [i don't know, seems to be in centimeters instead mm]
I know ho wto set before the diameter, but probably is an option in Pro-E to let MOldflow recognize the correct unit system.
Bye
Marco
