Discussion Groups
Simulation Moldflow Adviser
Active Member
bjdavison
Accepted Solution
Import Runner System from 3D CAD
1229 Views, 3 Replies
04-18-2013 09:44 AM
I tried to search for some information but came up empty.  Basically I was wondering how to import a runner system creaded in 3D CAD to Moldflow Plastics Advisor 2014.  Any help would be appreciated.
Brad
Please use plain text.
Product Support
nordhb
Re: Import Runner System from 3D CAD
04-19-2013 01:19 AM in reply to: bjdavison
in the cad system: extract center lines of runner system as lines/curves.
Trim lines in the break points, where runners changes direction.
Export the center lines of runner system as iges curves from the cad system.
Before starting import, the geometry setting should be Single cavity or Multi-cavity.
In Autodesk Simulation Moldflow Adviser, go to Geometry.
Click Feed System, down-arrow
Import Runners
File type : *.igs
and select the iges-file.
Then Apply
When importing an *.igs or *.iges file, the process will import each segment of the runner system as a centre (axis) line, and apply default runner system dimensions. You can the change and set appropriate runner properties.
Hope this helps.
Berndt
Berndt Nordh
Active Member
bjdavison
04-23-2013 10:29 AM in reply to: nordhb
Sounds good, now I just need to figure out how to do this in my CAD program. Thanks for the reply.
New Member
rustcat
06-27-2013 07:31 AM in reply to: bjdavison
I heard 3D runners can be directly designed in Moldex?  Is that true?
