Hi all,
I would like to find more material database ( file with extension 21000.udb). Where can I get it?
Thanks all
the material database for Autodesk Moldflow Adviser is updated with new releases.
This is applied when installing the software.
To get more material data files, udb-files, what you can do:
- ask the material supplier for an udb-file of the specific material data you are looking for
- if you have measured data, raw data, of material you can contact datafittingmoldflow@autodesk.com
and get measured data fitted and an udb-file for analysis in return.
(material supplier might have measured data on this material?)
Berndt
