Good morning everybody,
I am working with the student version of "Autodesk Simulation Moldflow Adviser 2014".
Is it possible to run a fiber orientation simulation and export the tensor of the fiber orientation?
Regards
Robert
Solved by nordhb. Go to Solution.
if the material is fiber filled, the fiber solver in Autodesk Simulation Moldflow Adviser will be used.
This is important for the further warpage simulation, to get the mechanical properties from flow simulation.
Regarding more features such as export fiber orientation and more you need Autodesk Simulation Moldflow Synergy (user interface) and Autodesk Simulation Moldflow Insight (solver).
To compare products you have some information here:
http://www.autodesk.com/products/autodesk-simulation-family/compare/moldflow-products
Berndt
