Hallo,
for a project i need to export the temperature distribution after the moldflow process over the part into multiphysics.
I want to set this temperature distribution as a boudary condition in multiphysics.
Will this be possible?
Solved by nordhb. Go to Solution.
There is not an automatic process to get the temperature results from Moldflow into Simulation Mechanical/Multiphysics.
I do not want to assume that I understand what you are doing with the temperatures, so it would be helpful if you can answer these questions:
If it can be done manually, the difficulty is getting the temperature at the coordinate of the nodes in Mechanical/Multiphysics. If you can export the mesh from Moldflow in a format that Mechanical/Multiphysics can read (use the "File > Open" command and then the files of type drop-down to see the supported formats), it would be easier to do the work with the same mesh.
The answers to your questions:
1. I want to do a transient thermal analysis
2. I need the temperature as start temperature for the thermal analysis. The temperature has no further effects.
I tried to import some of the files i can safe or export in AMA. My problem is, the only file type witch I can export out of AMA is a .udm file. I think this file contains the temperature and coordinates of the mesh-nodes. But I have no idea how I can import this into multiphysics.
In Multiphysics i need a .to file to set a individual start-temperature for each node.
I think AMA doesn't work with a pre-given mesh - it re-meshes the part, so I can´t associate the temperature in the .udm file to the nodes of a, .stl or .stp file.
I hoped AMA could export the temperature to Multiphysics or has a Plugin for it.
Where can i find some information about the structure of the .udm file?
Autodesk Simulation Moldflow Adviser does not have the export of results feature as described.
You need Autodesk Simulation Moldflow Synergy/Insight for this.
In Moldflow Synergy you have different result export options.
You can also customize by API.
Regarding transient thermal analysis, if this is for the mold cooling cycle, this can be simulated in Moldflow Insight Cool FEM.
Berndt
