Anyone knows what the attached error is about?
The download starts but immediately gives this error.
Hi Peer,
are you connected by wifi or cable when getting this message?
My machine is connected by cable and the download starts as expected.
No error messages.
(Vista 64bit)
Are there some general restrictions to download for you?
Berndt
Hi Berndt
I'm on cable and I have no download restrictions.
I cannot seem to get through to the ftp server download without these errors.
Can I get to this file another way via http?
This place is only for 2010 downloads:
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=13030538
Hi Peer,
you can access the service pack from Subscription Center.
You need to have a valid account to login and download.
http://subscription.autodesk.com
you will find: Autodesk Moldflow Adviser 2011 Service Pack 3.
If you need further assistance in this matter, please contact you local support.
Berndt
Hi Berndt
All OK this way around - thanks!
But the culprit regarding the Auto-Revision-Update from within the program remains unsolved.
Hi Peer,
as I understand, a new revision available found.
You select type of host, key in file name and then as download starts, it stops immediately.
I tested this on Win 7 64-bit workstation, connected by cable.
It works as expected, and I cannot repeat what you see.
Berndt
Hi
I got the same problem in my office. Try other connection. As far as I understand it's security issues of both parts.
Tiago
