I did simulations for bell shaped part with walls of different thickness. Wall thickness ranges from 1,5 mm to 3 mm at the bottom of the bell, 4 to 5 mm in middle, 6 mm at the top of the bell. Part also has some thin walled ribs inside. I did two types od simulation - first with dual domain analysis, second one - 3D analysis. Average temperature differs the most - about 50 deg C. Pressure at end of fill differs about 4 MPa, 28 MPa for dual domain, 24 MPa for 3D. Which analysis is more reliable in this case. Import wizard advises using dual domain analysis.
Thanks for Your help.
Marcin
