Moldflow Adviser Forum
Welcome to Autodesk’s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
Direct (sprue) gate
1 REPLY 1
878 Views, 1 Reply
Direct (sprue) gate
i am studying the case of center-gated disk. So my dimensions are R = 57mm and thickness = t = 1.5mm.
From what i have understood, a direct gate is only a tapered cold sprue. So from the center of the disk, going
on z axis, i made a sprue of length = 51.5 + t = 53 mm. I searched and i found that average sprue lengths start
from 51 mm - 76 mm. So i wanted to keep it as short as possible. So i created a sprue with a start diameter
of 6 mm (injection side) and an end diameter of 3 mm (meeting cavity side).
So am i ok with the dimensions or should i create a gate too ? I am asking cause after the analysis, the presure
seems to be 0, all along the disk. Something is not going on well ..., that's why i am asking if i should make a gate, too.
Thanks and waiting for someone's reply,
Thodoris
1 REPLY 1
nordhb
this topic was posted a while ago, and maybe you already sorted it out.
If you get 0 pressure in result, it seems as the sprue/gate is not connected to cavity.
You need an injection location on cavity.
Model as Single cavity.
Then a gate and a sprue, with dimension of sprue.
Berndt
Berndt Nordh
