Moldflow Adviser Forum
Welcome to Autodesk’s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
Diference MF Adviser and Insight
3 REPLIES 3
1219 Views, 3 Replies
Hi all
I'm a new beginner with moldflow, we have MF Adviser and I would like to know what are the main diferences .
thanks
3 REPLIES 3
nordhb
please have a look at:
http://usa.autodesk.com/adsk/servlet/pc/index?id=12269104&siteID=123112
You can find brochures and compare features.
Berndt
Berndt Nordh
As mentioned, you could go to the links listed below, or you could look at the big picture. Moldflow Advisor is more wizard driven, and typically used by designers and engineers to check parts, molds, etc. in the design cycle. Moldflow Insight is often utilized by the "plastics" engineers who are used to running injection molding machines, they talk about resin properties, etc.
This is a generalization, but depending upon your background, or perhaps a specific need (Insight helps with Co-Injection molding, Gas-Assist injection molding, MuCell injection molding, Injection-Compression molding, and Birefringence Prediction.
Craig Preston
Director, Simulation Solutions
Saratech Engineering, Inc.
Lake Forest, CA
(949) 459-3880
cpreston@saratechinc.com
Thanks Craig
I guess for me at the moment MPA is enought but I do have some beginner questions that i will post in a new post, if you can help with your expirience that would be great.
thanks
