Discussion Groups
Simulation Moldflow Adviser
bernd.rosemann
CAE Data exchange
448 Views, 3 Replies
09-26-2012 11:22 PM
Hallo,
reading the Autodesk Símulation Moldflow Compare Website http://usa.autodesk.com/adsk/servlet/pc/compare/index?siteID=123112&id=14920771 there is a data exchange feature to autodesk simulation multiphysics from autodesk moldflow advisor ultimate.
Where is a documentation or tutorial available for that feature to transfer simlation results from moldflow to simulation multiphysics?
BR
Please use plain text.
Product Support
nordhb
Re: CAE Data exchange
10-01-2012 02:33 AM in reply to: bernd.rosemann
this is available in the in the wikihelp:
http://wikihelp.autodesk.com/Simulation_Mechanical/enu/2013/Help/0031-Autodesk31/0237-Setting_237/02...
There is also an validation document:
Autodesk Moldflow Structural Alliance 2012
Validation Report: Additional Data Mapping to Structural Analysis Packages
which you can access from subscription center:
http://subscription.autodesk.com/
Hope this helps.
Berndt
Berndt Nordh
bernd.rosemann
Re: CAE Data exchange (Moldflow/Multiphysics)
10-01-2012 09:23 AM in reply to: nordhb
wikihelp describes at section Use Moldflow Results - Step 2: "For parts that correspond to the plastic part(s) to be analyzed in Moldflow, set the Element Definition: Material Model to Moldflow. This is an anisotropic material model."
Where is this selection?
Selection Dialog Material Model
Kind regards
Bernd
Product Support
nordhb
10-01-2012 11:43 PM in reply to: bernd.rosemann
regarding the analysis type in Autodesk Simulation Multiphysics.
The Moldflow element definition is available in Analysis type:
Linear or Non-linear
If you for example select Linear > Static Stress with Linear Material Model
and then enter Element Definition you will see the Material Model: Moldflow
Or if you for example select Nonlinear > MES with Nolinear Material Model
If you have further questions about using Autodesk Simulation Multiphysics,
please, post in forum http://forums.autodesk.com/t5/Autodesk-Simulation-Mechanical/bd-p/396
Berndt
Berndt Nordh
