Moldflow Adviser Forum
Welcome to Autodesk’s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
BASF Material Data
1 REPLY 1
viveksingal
1196 Views, 1 Reply
BASF Material Data
I use TPU from BASF grade Elastollan C98 material for my application. Pl inform if material data for this material is available in the material data base i.e. in .udb file.
If not, How can I get this file? If I have to do measurements and then through your center get a .udb file, pl advice what all data is required?
1 REPLY 1
nordhb
in reply to: viveksingal
Autodesk Moldflow Adviser 2013 SP2 does not have this material grade, Elastollan C 98, from what I can see.
The recommendation is to contact the material supplier to get an udb-file (material data file for analysis) of requested material.
If you have measured data, raw data, of material you can contact datafittingmoldflow@autodesk.com
and they will provide documents where to enter raw data.
If all completed you will get measured data fitted and an udb-file for analysis in return.
You can also contact:
Autodesk Moldflow Plastics Labs
http://usa.autodesk.com/adsk/servlet/item?id=13151393&siteID=123112&linkID=13030537
and test the material as service.
Berndt
Berndt Nordh
