Discussion Groups
Simulation Moldflow Adviser
New Member
0 Kudos
AutoDesk Security Failure
502 Views, 3 Replies
12-05-2012 10:37 AM
Hi just installed AutoDesk MoldFlow 2010-R2 on a Windows 7 64bit machine and when going to launch it I received the attached screen shot.
I've got the correct license server, it's pingable, and the other users who are all on Windows XP 32bit are having no issues.
I get the same error after installing Moldflow 2011.
I've checked the license server manager, and it's pointing to the correct license.
Any help would be awesome!
Thanks!
895 Kudos
Re: AutoDesk Security Failure
12-05-2012 02:49 PM in reply to: darken98
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
Moldflow licensing is a little different than other products, to my memory.  I have solved this problem for a customer in the past but failed to take down any notes on what I did.  I do know there is additional license configuration that needs to take place to make it work though.
New Member
0 Kudos
12-13-2012 06:40 AM in reply to: TravisNave
i have the same problem as darken98.
"Autodesk security failure"
is there any solution to fix that problem?
New Member
0 Kudos
12-26-2012 04:19 PM in reply to: kamel.achour
Hi, have this problem ("Autodesk security failure") too... May be, something wrong with my russian version Windows 7 x64?
