Moldflow Adviser Forum
Welcome to Autodesk’s Moldflow Adviser Forums. Share your knowledge, ask questions, and explore popular Moldflow Adviser topics.
ASMA 2013 Temp Files
1 REPLY 1
MartinSchultz
825 Views, 1 Reply
Ran out of disc space today so I went searching for files to remove.  Does anyone have a script for automatically cleaning out the \ASMA 2013 Temporary Files directory?  Any reason why this shouldn't be done every time you properly exit the software?
1 REPLY 1
Paul.Larter
in reply to: MartinSchultz
Hello
If you open the Job Mangaer from the 'Getting Started' tab if you do not have a project open or from the 'Analysis' tab if you do. Click on the properties button near the bottom left of the Job Manager dialog.
You will notice in the Job Manager Properties GUI that pops up that at the bottom you have 'Delete temporary files older than:' option. By default this is set to 7d, which means 7 days. You can change this to 1d if you wish. This will make the job manager retain the temproary files for this period before automatic deletion.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Paul Larter
