Ran out of disc space today so I went searching for files to remove. Does anyone have a script for automatically cleaning out the \ASMA 2013 Temporary Files directory? Any reason why this shouldn't be done every time you properly exit the software?
Solved by Paul.Larter. Go to Solution.
Hello
If you open the Job Mangaer from the 'Getting Started' tab if you do not have a project open or from the 'Analysis' tab if you do. Click on the properties button near the bottom left of the Job Manager dialog.
You will notice in the Job Manager Properties GUI that pops up that at the bottom you have 'Delete temporary files older than:' option. By default this is set to 7d, which means 7 days. You can change this to 1d if you wish. This will make the job manager retain the temproary files for this period before automatic deletion.
