Is it possible to add new material information to the materials database for the Adviser 2012 software?
You can import a .udb file directly into the Moldflow database. The .udb file contains the necessary information to perform an analysis. This material will only exist in your database. I hope this helps.
if you have measured data, raw data, of material you can contact
datafittingmoldflow@autodesk.com
and get the measured data fitted and an udb-file for analysis in return.
Autodesk Moldflow Plastics Labs information at:
http://usa.autodesk.com/adsk/servlet/item?id=13151393&siteID=123112&linkID=13030537
Hope this helps.
Berndt
